Apache inaccessible de l'extérieur (DEBIAN 9)
ddjaff
bonsoir,
J'aurai souhaité rendre accessible un site web présent actuellement sur mon poste debian 9. Il s'agit d'un site wordpress qui se trouve sous /var/www/html/monsite/
Le routage côté box fonctionne puisque j'arrive à me logguer de l'extérieur sur la page d'admin phpmyadmin par l'url suivante : mon.dtdns.net/phpmyadmin/
Quand je tente mon.dtdns.net/monsite/ il ne se passe rien
Par contre en local via l'url 192.161.1.x/monsite/ est accessible
A ce stade, je suis resté sur le port 80 standard et n'ai pas modifié le contenu des fichiers suivants
/etc/apache2/apache2.conf
/etc/apache2/sites-enabled/ports.conf
<VirtualHost *:80>
	# The ServerName directive sets the request scheme, hostname and port that
	# the server uses to identify itself. This is used when creating
	# redirection URLs. In the context of virtual hosts, the ServerName
	# specifies what hostname must appear in the request's Host: header to
	# match this virtual host. For the default virtual host (this file) this
	# value is not decisive as it is used as a last resort host regardless.
	# However, you must set it for any further virtual host explicitly.
	#ServerName www.example.com
	ServerAdmin webmaster@localhost
	DocumentRoot /var/www/html
	# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
	# error, crit, alert, emerg.
	# It is also possible to configure the loglevel for particular
	# modules, e.g.
	#LogLevel info ssl:warn
	ErrorLog ${APACHE_LOG_DIR}/error.log
	CustomLog ${APACHE_LOG_DIR}/access.log combined
	# For most configuration files from conf-available/, which are
	# enabled or disabled at a global level, it is possible to
	# include a line for only one particular virtual host. For example the
	# following line enables the CGI configuration for this host only
	# after it has been globally disabled with "a2disconf".
	#Include conf-available/serve-cgi-bin.conf
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
/etc/apache2/ports.conf
# If you just change the port or add more ports here, you will likely also
# have to change the VirtualHost statement in
# /etc/apache2/sites-enabled/000-default.conf
Listen 80
<IfModule ssl_module>
	Listen 443
</IfModule>
<IfModule mod_gnutls.c>
	Listen 443
</IfModule>
Je sèche un peu et si quelqu'un peut m'éclairer j'suis preneur !
Apache ne servira que la page par défaut si tu n'as pas de vhost avec le chemin vers le site que tu souhaite "servir"
Un truc du genre:
<VirtualHost 192.168.1.200:80>
	DocumentRoot /var/www/html/monsite
</VirtualHost>
Initile de cacher ton IP privée on va pas t'attaquer avec ça...
