si jepasse le 'own_window_type' a 'override' , la bordure n'apparait plus mais je perds la transparence
j'ai beau trifouiller le code je ne vois pas comment forcer la chose ....
une idee ?
dans un premier temps, voici le conky que j'utilise :Grhim a écrit :je n'arrive pas dans la config a enlever les bords de fenetre conky,
j'ai beau trifouiller le code je ne vois pas comment forcer la chose ....![]()
une idee ?
conky.config = {
alignment = 'top_right',
background = false,
border_width = 1,
cpu_avg_samples = 2,
default_color = 'green',
default_outline_color = 'green',
default_shade_color = 'green',
draw_borders = false,
draw_graph_borders = false,
draw_outline = false,
draw_shades = false,
double_buffer= true,
use_xft = true,
font = 'DejaVu Sans Mono:size=07',
gap_x = 5,
gap_y = 60,
minimum_height = 5,
minimum_width = 5,
net_avg_samples = 2,
no_buffers = true,
out_to_console = false,
out_to_stderr = false,
extra_newline = false,
own_window = true,
own_window_argb_visual = true,
own_window_argb_value = 10,
own_window_transparent = true,
own_window_hints = undecorated,below,skip_taskbar,skip_pager,
own_window_class = 'Conky',
own_window_type = 'desktop',
stippled_borders = 0,
update_interval = 0.500,
uppercase = false,
use_spacer = 'none',
show_graph_scale = false,
show_graph_range = false
# Conky, a system monitor, based on torsmo
# Any original torsmo code is licensed under the BSD license
# All code written since the fork of torsmo is licensed under the GPL
# Please see COPYING for details
# Copyright (c) 2004, Hannu Saransaari and Lauri Hakkarainen
# Copyright (c) 2005-2010 Brenden Matthews, Philip Kovacs, et. al. (see AUTHORS)
# All rights reserved.
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
alignment top_left
background no
border_width 1
cpu_avg_samples 2
default_color white
default_outline_color white
default_shade_color white
draw_borders no
draw_graph_borders yes
draw_outline no
draw_shades no
use_xft yes
xftfont DejaVu Sans Mono:size=12
gap_x 5
gap_y 60
minimum_size 5 5
net_avg_samples 2
no_buffers yes
out_to_console no
out_to_stderr no
extra_newline no
own_window yes
own_window_class Conky
own_window_type desktop
stippled_borders 0
update_interval 1.0
uppercase no
use_spacer none
show_graph_scale no
show_graph_range no
TEXT
${scroll 16 $nodename - $sysname $kernel on $machine | }
$hr
${color grey}Uptime:$color $uptime
${color grey}Frequency (in MHz):$color $freq
${color grey}Frequency (in GHz):$color $freq_g
${color grey}RAM Usage:$color $mem/$memmax - $memperc% ${membar 4}
${color grey}Swap Usage:$color $swap/$swapmax - $swapperc% ${swapbar 4}
${color grey}CPU Usage:$color $cpu% ${cpubar 4}
${color grey}Processes:$color $processes ${color grey}Running:$color $running_processes
$hr
${color grey}File systems:
/ $color${fs_used /}/${fs_size /} ${fs_bar 6 /}
${color grey}Networking:
Up:$color ${upspeed eth0} ${color grey} - Down:$color ${downspeed eth0}
$hr
${color grey}Name PID CPU% MEM%
${color lightgrey} ${top name 1} ${top pid 1} ${top cpu 1} ${top mem 1}
${color lightgrey} ${top name 2} ${top pid 2} ${top cpu 2} ${top mem 2}
${color lightgrey} ${top name 3} ${top pid 3} ${top cpu 3} ${top mem 3}
${color lightgrey} ${top name 4} ${top pid 4} ${top cpu 4} ${top mem 4}
je n'ai pas de demarreur automatique sur enlightenment, c'est fait a la mano dans les rc.d (a l'ancienne !! :) )DbFr871 a écrit :Pour le lancer au démarrage du bureau, je l'ai fait depuis :
Gestionnaire de paramètres
Session et démarrage
et je l'ai inséré dans la liste "Démarrage automatique"
si tu as un .conkyrc c'est lui qui est pris en charge par rapport a /etc/conkyDbFr871 a écrit : je me demande, s'il a une influence sur ce que j'ai indiqué précédemment... ? !!!
https://doc.ubuntu-fr.org/conkyConky passe en version 1.10. Cela entraîne de gros changement sur la configuration :
Mettre la partie configuration dans :
conky.config = { ... }
Mettre la partie TEXT dans :
conky.text = [[ ... ]]
Toutes les valeurs doivent être précédé de "=" dans la partie configuration
Finir chaque ligne par une virgule ","
Remplacer tous les "yes"/"no" en "true"/"false" (sans les guillemets)
Toutes les valeurs autre que nombres,"true" et "false", doivent être entre quotes (ex: use_space = 'left' )
Les commentaires doivent commencer avec "–" à la place de "#"
