Je viens d'installer debian8. J'ai gardé la même config, avec Fail2Ban notamment. C'est un site DRUPAL 8.
Mais depuis, je n'arrête pas d'avoir ces messages en nombre important; par exemple :
- apache-multiport: banned 82.124.133.14 from [Mon serveur]
The IP 82.124.133.14 has just been banned by Fail2Ban after 8 attempts against apache-multiport.
Lines containing IP:82.124.133.14 in /var/log/apache*/*error.log
[Sat Aug 05 20:16:25.072914 2017] [access_compat:error] [pid 31505] [client 82.124.133.14:49417] AH01797: client denied by server configuration: /var/www/apple-touch-icon-precomposed.png
[Sat Aug 05 20:16:25.217709 2017] [access_compat:error] [pid 31505] [client 82.124.133.14:49417] AH01797: client denied by server configuration: /var/www/apple-touch-icon.png
[Sat Aug 05 20:16:25.365550 2017] [access_compat:error] [pid 31505] [client 82.124.133.14:49417] AH01797: client denied by server configuration: /var/www/system
[Sat Aug 05 20:16:25.510550 2017] [access_compat:error] [pid 31505] [client 82.124.133.14:49417] AH01797: client denied by server configuration: /var/www/favicon.ico
[Sat Aug 05 20:16:25.657943 2017] [access_compat:error] [pid 31505] [client 82.124.133.14:49417] AH01797: client denied by server configuration: /var/www/apple-touch-icon-precomposed.png
[Sat Aug 05 20:16:25.806388 2017] [access_compat:error] [pid 31505] [client 82.124.133.14:49417] AH01797: client denied by server configuration: /var/www/apple-touch-icon.png
[Sat Aug 05 20:16:25.949427 2017] [access_compat:error] [pid 31505] [client 82.124.133.14:49417] AH01797: client denied by server configuration: /var/www/system
[Sat Aug 05 20:16:26.098396 2017] [access_compat:error] [pid 31505] [client 82.124.133.14:49417] AH01797: client denied by server configuration: /var/www/favicon.ico
Dans mon .htaccess, j'ai :
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_URI} !=/favicon.ico
RewriteRule ^ index.php [L]
et dans mon apache j'ai bien autorisé l'accès à mon répertoire :
<Directory /var/www/>
Options -Indexes -FollowSymLinks -MultiViews -Includes -ExecCGI +IncludesNOEXEC
AllowOverride All
Require all granted
</Directory>
> J'ai mis dans www le favicon.ico au cas où mais rien ne change.
AVEZ VOUS UNE IDEE de ce qu'il faut faire ?
Cordialement
yonamoke
Erreur "AH01797"
- Grhim
exemple :
https://www.apachelounge.com/viewtopic.php?p=28631
Options Indexes FollowSymLinks Multiviews
AllowOverride All
<RequireAll>
Require all granted
Require not ip 188.40 46.4 176.9 46.166 46.21 78.46 91.207.7.21 0.0.0.0 91.207.7.182
</RequireAll>
</Directory> Debian Stable + Testing -.- Parrot OS - Kali Exegol -.- Raspberry IPFire
yonamoke
merci mais il me semble que ma déclaration soit dans les règles :
Je n'ai pas envie néanmoins de l'index, du suivi de lien et multiviews d'ou ma déclaration
AllowOverride All
Require all granted
</Directory>
qu'est ce qui ne va pas ?
merci
AllowOverride All
Require all granted
</Directory>
merci
- Grhim
pas chez moi , mais regarde ici https://wiki.apache.org/httpd/ClientDen ... figuration
Pourquoi old stable alors que Debian9 est dans les racks depuis des semaines ?
Tu parles de quelle config exactement ??? Des configs de Jessie, Wheezy ? Apache, Fail2ban ?
Quelles sont les version de Apache2 (Je suppose qu'on parle d'apache), Fail2ban ?
yonamoke a écrit : 05 août 2017, 22:05Je viens d'installer debian8. J'ai gardé la même config, avec Fail2Ban notamment. C'est un site DRUPAL 8.
yonamoke
lol, j'ai bien précisé en entête debian8, drupal 7 (faute j'avais mis drupal8), et bien fail2ban.
Pour apache, c'est bien 2.4.
le pourquoi ?
Simple, le contexte. Site drupal 7 existant, à refaire en 8 très prochainement.
Lui le futur sera développé en debian 9, et drupal 8.
L'existant sur drupal 7, c'est une obligation pour la maintenance.
yonamoke
le pourquoi ?
yonamoke
- Grhim
possible d'avoir toute ta configuration d'Apache ? car l'erreur n'est pas dans les fichiers que tu nous a donné
A moins que la conf d'apache vienne d'un Apache 2.2 ???
Il y a eu des changements entre 2.2 et 2.4.
yonamoke
hello,
désolé de ma réponse tardive, mais j'ai été en déplacement.
Voici la config :
(j'ai remplacé mon site par xxx.fr et my_ip par mon IP)
<VirtualHost *:443>
DocumentRoot /var/www
ServerAdmin xxx@gmail.com
ServerName www.xxx.fr
ServerAlias xxx.fr
<Directory />
Options None
AllowOverride None
Require all denied
Allow from my_ip
</Directory>
Options -Indexes -FollowSymLinks -Multiviews
AllowOverride All
<RequireAll>
Require all granted
</RequireAll>
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Require all granted
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
LogLevel error
ServerSignature Off
CustomLog ${APACHE_LOG_DIR}/ssl_access.log combined
# SSL Engine Switch:
# Enable/Disable SSL for this virtual host.
SSLEngine on
[... My config ssl qui marche avec debian7]
</VirtualHost>
voilà.
yonnel
Voici la config :
<VirtualHost *:443>
ServerAlias xxx.fr
<Directory />
Options None
AllowOverride None
Require all denied
Allow from my_ip
</Directory>
AllowOverride All
<RequireAll>
Require all granted
</RequireAll>
</Directory>
AllowOverride None
Require all granted
</Directory>
LogLevel error
ServerSignature Off
SSLEngine on
</VirtualHost>
voilà.
yonnel
Commence par virer ou commenter tous les Require all denied
Il y a une incohérence entre:
<Directory />
Require all denied
et
<RequireAll>
Require all granted
<Directory />
Require all denied
et
<RequireAll>
Require all granted
yonamoke
Je ne comprend pas pourquoi ?
1/ <directory /> vise à protéger mon serveur, hors mon site web (sauf moi)
==> denied
2/ <Directory /var/www/> vise à autoriser tout le monde l'aller su rmon serveur Web
==> DocumentRoot /var/www
==>all granted
pourquoi incohérence ?
merci
yo
==> denied
==>all granted
merci
yo
Salut
A partir du moment ou tu déclare /var/www comme document root, quand tu fais référence à "/" c'est équivalent à /var/www (le document root du vhost).
Ce n'est pas possible de remonter plus haut que le document root.
A quel dossier penses tu quand tu mets "/" ? /var ? /var/www ? / ?
yonamoke
bonjour lol,
quand je fais "/", je pense à mon répertoire principal du serveur : "/".
je pensais que je protégeais de tout accès ce qui est en dessous de /var/www !
Si je fais "<Directory /var/www/>", je met accès à mon web.
Et le reste, en dessous, de "/" et de "/var", dois-je le protéger ? Et comment ?
quand tu m'as interpellé dessus, je me suis rendu compte que je faisais sans doute une bêtise et ce que tu dis est évident.
Mais dans la protection d'un serveur VDS, dans ma déclaration "<VirtualHost ...", excepté la déclaration
AllowOverride None
Require all granted
</Directory>
je dois faire autre chose que ma "<Directory /var/www/>" ?
merci pour ton aide
yo
AllowOverride None
Require all granted
</Directory>
merci pour ton aide
yo
ça s'imbrique en cascade (Du plus près de la racine au plus loin)
Regarde le fichiers default.conf d'apache:
Le fait de fixer le DocumentRoot suffit: Impossible de remonter au dessus de /html
Tes consignes (Allow ou pas, etc)
</Directory>
<VirtualHost IP:80>
DocumentRoot /var/www/monsite
<Directory /var/www/monsite>
</Directory>
Ici tes consignes cgi-bin ou fast-cgi
</VirtualHost>Code : Tout sélectionner
<VirtualHost *:80>
DocumentRoot /var/www/html
</VirtualHost>Règles d'usage du forum. Signalez si vous avez posté votre question sur un autre forum. Explications ici
Oui, pardon. En dessous... ;-)
Tu as réglé ton problème d’accès ?
