Depuis un moment j'ai un soucis d'installation des drivers Nvidia avec SGFXI.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
   executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'...
   Checking for libglvnd installation.
   Checking libGLdispatch...
   Checking libGLdispatch dispatch table
   Checking call through libGLdispatch
   All OK
   libGLdispatch is OK
   Checking for libGLX
   Can't load libGLX from libGLX.so.0: libGLX.so.0: cannot open shared object file: No such file or directory
-> An incomplete installation of libglvnd was found. Do you want to install a full copy of libglvnd? This will overwrite any existing libglvnd libraries. (Answer: Abort installation.)
ERROR: Installation has failed.  Please see the file '/var/log/nvidia-installer.log' for details.  You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
  ERROR: (245) The nvidia installer exited with the error: 1
A copy of this driver installer error log is also here: /var/log/sgfxi/sgfxi.logJ'ai bien essayé de réinstaller libglvnd0 ou de le remplacer par libglvnd0-nvidia, rien à faire, toujours cette maudite erreur.
J'ai trouvé comme contournement de lancer directement le "run" Nvidia avec cette commande:
sh ./NVIDIA-Linux-x86_64-384.59.run -aqs --install-libglvndSuis-je le seul à avoir ce problème ?
