pulseaudio supprimer apres mise a jour Le sujet est résolu
tuxique
Une mise a jour a désinstaller pulseaudio et je n'arrive pas le réinstaller.
sudo apt install pulseaudio
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libavresample4 : Depends: libavutil56 (= 7:4.3.2-0+deb11u2) but 7:4.4-5 is to be installed
E: Unable to correct problems, you have held broken packages.
~$ grep "remove " /var/log/dpkg.log
2021-08-22 16:54:43 remove pulseaudio-module-gsettings:amd64 14.2-2 <none>
2021-08-22 16:54:43 remove pulseaudio-module-bluetooth:amd64 14.2-2 <none>
2021-08-22 16:54:43 remove libasound2-plugins:i386 1.2.5-1 <none>
2021-08-22 16:54:43 remove libavresample4:i386 7:4.3.2-0+deb11u2 <none>
2021-08-22 16:54:44 remove pulseaudio:amd64 14.2-2 <none>
2021-08-22 16:54:44 remove libasound2-plugins:amd64 1.2.5-1 <none>
2021-08-22 16:54:47 remove libavresample4:amd64 7:4.3.2-0+deb11u2 <none>
2021-08-22 16:54:48 remove libcanberra-pulse:amd64 0.30-7+b1 <none>
2021-08-22 16:54:48 remove plasma-pa:amd64 4:5.21.5-2 <none>
et aptitude a supprime ceci quand j'ai tente aptitude install pulseaudio
2021-08-22 17:32:31 remove pasystray:amd64 0.7.1-1+b1 <none>
2021-08-22 17:39:47 remove va-driver-all:i386 2.12.0-2 <none>
2021-08-22 17:39:48 remove i965-va-driver:i386 2.4.1+dfsg1-1 <none>
2021-08-22 17:39:48 remove intel-media-va-driver:i386 21.3.1+dfsg1-1 <none>
2021-08-22 17:39:48 remove libavcodec58:i386 7:4.4-5 <none>
2021-08-22 17:39:48 remove libaom0:i386 1.0.0.errata1-3 <none>
2021-08-22 17:39:48 remove libswresample3:i386 7:4.4-5 <none>
2021-08-22 17:39:48 remove libavutil56:i386 7:4.4-5 <none>
2021-08-22 17:39:48 remove libcodec2-0.9:i386 0.9.2-4 <none>
2021-08-22 17:39:48 remove libdav1d4:i386 0.7.1-3 <none>
2021-08-22 17:39:48 remove libsoxr0:i386 0.1.3-4 <none>
2021-08-22 17:39:48 remove libgomp1:i386 11.2.0-2 <none>
2021-08-22 17:39:48 remove libsm6:i386 2:1.2.3-1 <none>
2021-08-22 17:39:48 remove libice6:i386 2:1.0.10-1 <none>
2021-08-22 17:39:48 remove libigdgmm11:i386 21.2.1+ds1-2 <none>
2021-08-22 17:39:49 remove libkwineffects12a:amd64 4:5.20.5-1 <none>
2021-08-22 17:39:49 remove libllvm11:i386 1:11.0.1-2 <none>
2021-08-22 17:39:49 remove libx265-192:i386 3.4-2 <none>
2021-08-22 17:39:49 remove libnuma1:i386 2.0.12-1+b1 <none>
2021-08-22 17:39:49 remove libplacebo72:amd64 2.72.2-1 <none>
2021-08-22 17:39:49 remove librsvg2-common:i386 2.50.3+dfsg-1 <none>
2021-08-22 17:39:49 remove librsvg2-2:i386 2.50.3+dfsg-1 <none>
2021-08-22 17:39:49 remove libshine3:i386 3.1.1-2 <none>
2021-08-22 17:39:49 remove libsnappy1v5:i386 1.1.8-1 <none>
2021-08-22 17:39:49 remove libspeexdsp1:i386 1.2~rc1.2-1.1 <none>
2021-08-22 17:39:49 remove libtdb1:i386 1.4.3-1+b1 <none>
2021-08-22 17:39:49 remove libva-drm2:i386 2.12.0-2 <none>
2021-08-22 17:39:50 remove vdpau-driver-all:i386 1.4-3 <none>
2021-08-22 17:39:50 remove libvdpau-va-gl1:i386 0.4.2-1+b1 <none>
2021-08-22 17:39:50 remove libva-x11-2:i386 2.12.0-2 <none>
2021-08-22 17:39:50 remove libva2:i386 2.12.0-2 <none>
2021-08-22 17:39:50 remove mesa-vdpau-drivers:i386 21.2.1-1 <none>
2021-08-22 17:39:50 remove libvdpau1:i386 1.4-3 <none>
2021-08-22 17:39:50 remove libwebpmux3:i386 0.6.1-2.1 <none>
2021-08-22 17:39:50 remove libwebrtc-audio-processing1:i386 0.3-1+b1 <none>
2021-08-22 17:39:50 remove libx264-160:i386 2:0.160.3011+gitcde9a93-2.1 <none>
2021-08-22 17:39:50 remove libxtst6:i386 2:1.2.3-1 <none>
2021-08-22 17:39:50 remove libxvidcore4:i386 2:1.3.7-1 <none>
2021-08-22 17:39:50 remove libzvbi0:i386 0.2.35-18 <none>
2021-08-22 17:39:51 remove mesa-va-drivers:i386 21.2.1-1 <none>
2021-08-22 17:39:51 remove python3-slip-dbus:all 0.6.5-3 <none>
2021-08-22 17:39:51 remove python3-decorator:all 4.4.2-2 <none>
2021-08-22 17:39:51 remove python3-slip:all 0.6.5-3 <none>
2021-08-22 17:39:51 remove python3-selinux:amd64 3.1-3 <none>
2021-08-22 17:39:52 remove rtkit:amd64 0.13-4 <none>
~/Desktop$ sudo dpkg -i pulseaudio_14.2-2_amd64.deb
Selecting previously unselected package pulseaudio.
(Reading database ... 434600 files and directories currently installed.)
Preparing to unpack pulseaudio_14.2-2_amd64.deb ...
Unpacking pulseaudio (14.2-2) ...
dpkg: dependency problems prevent configuration of pulseaudio:
pulseaudio depends on libasound2-plugins; however:
Package libasound2-plugins:amd64 is not installed.
dpkg: error processing package pulseaudio (--install):
dependency problems - leaving unconfigured
Processing triggers for dbus (1.12.20-2) ...
Processing triggers for man-db (2.9.4-2) ...
Errors were encountered while processing:
pulseaudio
~/Desktop$ sudo apt install libasound2-plugins
You might want to run 'apt --fix-broken install' to correct these.
libasound2-plugins : Depends: libavresample4 (>= 7:4.0) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
~/Desktop$ sudo apt install libavresample4
pulseaudio : Depends: libasound2-plugins but it is not going to be installed
Recommends: rtkit but it is not going to be installed
~/Desktop$ sudo apt --fix-broken install
Correcting dependencies... Done
The following packages will be REMOVED:
pulseaudio
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 6,937 kB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
Operating System: Debian GNU/Linux SID
KDE Plasma Version: 5.24.4
KDE Frameworks Version: 5.90.0
Qt Version: 5.15.2
Kernel Version: 5.14.0-1-amd64 (64-bit)
Graphics Platform: X11
tuxique
voila ce que j'ai fais, j'ai downgrade mes paquet a leur version anterieur avec http://snapshot.debian.org/ ce qui a remis ffmpeg a sa version avant l'upgrade problématique. j'ai réinstaller pulseaudio sans problème de dépendance et j'ai effacer le contenue de ~/.config/pulse et systemctl --user restart pulseaudio pour qu'il détecte le matériel a nouveau.
voila ce qui arrive si je fait un full-upgrade :
apt full-upgrade
Calculating upgrade... Done
libasound2-plugins libavresample4 libcanberra-pulse plasma-pa pulseaudio pulseaudio-module-bluetooth pulseaudio-module-gsettings
The following packages will be upgraded:
ffmpeg libavcodec58 libavdevice58 libavfilter7 libavformat58 libavutil56 libpostproc55 libswresample3 libswscale5
9 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
Need to get 9,966 kB of archives.
After this operation, 8,594 kB disk space will be freed.
Abort.
ces paquets vont rester en kept back pour le moment, car ils suppriment des composants du système essentiels, et je sais pas comment dealer avec ça.
Qt Version: 5.15.2
vv222
La proposition de suppression de pulseaudio que tu observes n’est pas spécifique à ta configuration, j’observe la même chose sur ma Debian Sid.
C’est dû au paquet libavresample4 qui pour l’instant n’est pas encore disponible dans la même versions que les autres bibliothèques libav*, et devrait probablement être corrigé d’ici quelques jours par la mise à disposition d’une nouvelle version de cette bibliothèque.
vv222
Ah, après vérification, la nouvelle version du paquet libasound2-plugins débloque la situation en ne dépendant plus de libavresample4. Tu peux donc déjà réinstaller pulseaudio sur une Sid à jour.
