L'objectif est d'utiliser ma seconde carte (NVIDIA) dans une machine virtuelle
Si quelqu'un s'y connaît ou à une idée, il est le bienvenu.
$ lspci -nn | grep NVIDIA
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF108 [GeForce GT 630] [10de:0f00] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation GF108 High Definition Audio Controller [10de:0bea] (rev a1)
$ uname -a
Linux tor 4.5.0-2-amd64 #1 SMP Debian 4.5.5-1 (2016-05-29) x86_64 GNU/Linux
$ egrep -q '^flags.*(svm|vmx)' /proc/cpuinfo && echo virtualization extensions available
GRUB_CMDLINE_LINUX_DEFAULT="append intel_iommu=on vfio_iommu_type1.allow_unsafe_interrupts=1 pcie_acs_override=downstream"
$ dmesg |grep pci-stub
[ 2.084458] pci-stub: add 10DE:0F00 sub=FFFFFFFF:FFFFFFFF cls=00000000/00000000
[ 2.084513] pci-stub 0000:01:00.0: claimed by stub
#!/bin/bash
configfile=/etc/vfio-pci.cfg
vfiobind() {
dev="$1"
vendor=$(cat /sys/bus/pci/devices/$dev/vendor)
device=$(cat /sys/bus/pci/devices/$dev/device)
if [ -e /sys/bus/pci/devices/$dev/driver ]; then
echo $dev > /sys/bus/pci/devices/$dev/driver/unbind
fi
echo $vendor $device > /sys/bus/pci/drivers/vfio-pci/new_id
modprobe vfio-pci
cat $configfile | while read line;do
echo $line | grep ^# >/dev/null 2>&1 && continue
vfiobind $line
done
sudo qemu-system-x86_64 -enable-kvm -M q35 -m 4096 -cpu host \
-smp 4,sockets=1,cores=4,threads=1 \
-device ioh3420,bus=pcie.0,addr=1c.0,multifunction=on,port=1,chassis=1,id=root.1 \
-device vfio-pci,host=01:00.0,bus=root.1,addr=00.0,multifunction=on,x-vga=on \
-hda '/home/laurent/disk1.qcow2' \
-boot menu=on
exit 0
$ sudo ./seven.sh 0000:01:00.0
qemu-system-x86_64: -device vfio-pci,host=01:00.0,bus=root.1,addr=00.0,multifunction=on,x-vga=on: vfio: error, group 1 is not viable, please ensure all devices within the iommu_group are bound to their vfio bus driver.
qemu-system-x86_64: -device vfio-pci,host=01:00.0,bus=root.1,addr=00.0,multifunction=on,x-vga=on: vfio: failed to get group 1
qemu-system-x86_64: -device vfio-pci,host=01:00.0,bus=root.1,addr=00.0,multifunction=on,x-vga=on: Device initialization failed
