Comme ce n'est pas spécifiquement une demande de support Debian, je poste dans Pause Café.
Je dois rajouter 32 Go de Ram ( 4x8 ) dans l'un de mes serveurs Dell PowerEdge R720 qui en possède actuellement 16 Go ( 4x4 ), voir commande ci-dessous :
# dmidecode -t 17
# dmidecode 2.12
SMBIOS 2.7 present.
Handle 0x1100, DMI type 17, 34 bytes
Memory Device
Array Handle: 0x1000
Error Information Handle: Not Provided
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM_A1
Bank Locator: Not Specified
Type: [b]DDR3[/b]
Type Detail: [b]Synchronous Registered (Buffered)[/b]
Speed: [b]1600 MHz[/b]
Manufacturer: 002C00B3002C
Serial Number: 44255EAF
Asset Tag: 0F134763
Part Number: 9KSF51272PZ-1G6E2
Rank: 1
Configured Clock Speed: 1600 MHz
Handle 0x1101, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM_A2
Type: DDR3
Type Detail: Synchronous Registered (Buffered)
Speed: 1600 MHz
Serial Number: 44255EB0
Asset Tag: 0F134763
Rank: 1
Handle 0x1102, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM_A3
Type: DDR3
Speed: 1600 MHz
Serial Number: 44255EAE
Asset Tag: 0F134763
Rank: 1
Handle 0x1103, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM_A4
Type: DDR3
Speed: 1600 MHz
Serial Number: 44255EAD
Asset Tag: 0F134763
Rank: 1
Handle 0x1104, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Size: No Module Installed
Form Factor: DIMM
Set: 2
Locator: DIMM_A5
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Configured Clock Speed: Unknown
Handle 0x1105, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 2
Locator: DIMM_A6
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1106, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 2
Locator: DIMM_A7
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1107, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 2
Locator: DIMM_A8
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1108, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 3
Locator: DIMM_A9
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1109, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 3
Locator: DIMM_A10
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x110A, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 3
Locator: DIMM_A11
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x110B, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 3
Locator: DIMM_A12
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x110C, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 4
Locator: DIMM_B1
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x110D, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 4
Locator: DIMM_B2
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x110E, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 4
Locator: DIMM_B3
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x110F, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 4
Locator: DIMM_B4
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1110, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 5
Locator: DIMM_B5
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1111, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 5
Locator: DIMM_B6
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1112, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 5
Locator: DIMM_B7
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1113, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 5
Locator: DIMM_B8
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1114, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 6
Locator: DIMM_B9
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1115, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 6
Locator: DIMM_B10
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1116, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 6
Locator: DIMM_B11
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x1117, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 6
Locator: DIMM_B12
Type: DDR3
Speed: Unknown
Manufacturer:
Serial Number:
Asset Tag:
Part Number:
Rank: Unknown
Les instructions d'installation précisent que :
( source : http://www.dell.com/support/article/us/ ... /FR#issue4 )Les modules UDIMM et RDIMM et LRDIMM ne doivent pas être mélangés.
Et naturellement, je ne veux pas faire de bêtise.
Une piste pour que je puisse commander sereinement ?
